Just now, Doughmay said:
ok, so would i put the standoffs in before the mobo ormobo then standoffs? Would they go into the screw holes?
They screw into the case, and then the motherboard sits on top of the standoffs. I bet if you were to place the motherboard on its box, and power the system again, it'll turn on just fine.
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642161
so I put a box in between the mbo and the case to see if it will POST? lol? Not lieral? Literal?
Delta R5 Build
CPU: AMD RYZEN 1600 Purchased
Motherboard: ASUS PRIME B350-PLUS  Purchased
RAM: Corsair Vengeance 16GB DDR4 3000MHX (2X8GB) Purchased
CPU COOLER: DeepCool GAMMAXX 400 GT RGB Purchased
GPU: Gigabyte Xtreme Aorus 6gb GTX 1060 Purchased
Case: NZXT S340 (White) Purchased
PSU: EVGA 550B3 Purchased
HDD: WD Blue 1TB  Purchased
SSD: Sandisk SSD PLUS 120GB Purchased
Wifi Card: Asus PCE-N15 PCI-E 1X Purchased
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642170
No. Remove the motherboard from the chassis, and put it on its box with all of the components installed and connected as before, and turn it on(you'll have to short the pins for the power button to tell the system to turn on).
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642175
Oh, so remove the mounts and remove from case, then put on box, connect and try to power on
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642184
Can probably just put the header for the power button on if the wire is long enough and not attached to the case.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642185
Oh, so remove the mounts and remove from case, then connect and try to power on
Yes, but be sure it's resting on the box.
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642190
Yes, but to me it's more convenient to just short the pins together with a screwdriver if the board is not mounted within the case. Kind of circumstantial though.
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642194
OK, I tried it and it seems to be posting, its just nopt the videocard isn't running
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642332
What do you mean it's not running?
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642337
Like when I plug in HDMI the fans will spin, but stop. I'll move the
hdmi a little bit, and itll spin then stop
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642354
Are you getting a display output from the card?
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642360
No, monitor doesn't see it
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642365
Remove the card and see if the system POSTs.
What CPU are you using currently?
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642373
AMD FX 3820
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642377
1 minute ago, Doughmay said:
AMD FX 3820
Okay, so that's an issue. I was hoping you would have integrated graphics.
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642384
Yeah, I didnt want to waste money on an igpu lol.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642395
Do you have another graphics card you can put in the system temporarily? Is the HDMI cable plugged in fully on both ends?
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642398
Wait, I got it to display through the mob, idk how but it displayed.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642421
The motherboard probably has its own integrated graphics. A rarity, but it does happen.
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642422
Cool I'll get the standoffs and it should be good!
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642444
Well, the video card won't display though, right?
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642447
1 minute ago, Jamesxx said:
Uh just use display port or dvi lol the 460 has dvi
If everything is functional, including the HDMI port, cable, etc, then we have another issue. It's not necessarily as simple as "just use Displayport or DVI." You're assuming the card is functional. I'm not making any assumptions.
Edited by Godlygamer23
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642534
First off the chance of the graphics card being bad is slim he might need to try a different cable
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642540
That's why I asked him again about it. But again, this goes back to my point: It's not necessarily that simple. I didn't claim his card is bad. My claim is that it could be bad, and statistically speaking, it could be.
https://linustechtips.com/topic/670228-system-wont-post/page/2/#findComment-8642676
