Hi! So I recently assembled a build and I plugged everything in. Then when I go to turn it on, the fans spin, then stop, no POST. Nothing. So, I have no idea whats going on, I've checked the PSU, and the CPU, and RAM, they all are OK  I also replaced the motherboard. So do you have any idea whats going on? Halp?
Delta R5 Build
CPU: AMD RYZEN 1600 Purchased
Motherboard: ASUS PRIME B350-PLUS  Purchased
RAM: Corsair Vengeance 16GB DDR4 3000MHX (2X8GB) Purchased
CPU COOLER: DeepCool GAMMAXX 400 GT RGB Purchased
GPU: Gigabyte Xtreme Aorus 6gb GTX 1060 Purchased
Case: NZXT S340 (White) Purchased
PSU: EVGA 550B3 Purchased
HDD: WD Blue 1TB  Purchased
SSD: Sandisk SSD PLUS 120GB Purchased
Wifi Card: Asus PCE-N15 PCI-E 1X Purchased
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/
Do you have a video card installed?
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8641995
Yes. I have a powercolor RX460 powered through PCIE.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642028
2 minutes ago, wrathoftheturkey said:
You sure everything's plugged in right? All the power cables?
I think so, I've checked the mobo guide and it seems OK.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642034
Take it out and see if the system responds the same way.
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642049
Powered through PCIE? Do you mean PCIE slot or PCIE PSU cable?
I'd hope the latter.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642051
Technically, cards are powered through both. PCIe slots provide up to 75W of power for video cards.
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642055
Same response of the system.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642056
How many sticks of RAM do you have?
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642062
Well yeah, so I suppose any system would post regardless.
Just now, wrathoftheturkey said:
No, the 460 draws power straight from the MoBo, doesn't need a PSU cable (I think it's cause of the 75 W max limit through the slot). That's fine.
Oh. wow. News to me.
@Doughmay, do you have an LED screen telling you a two-digit number, or a motherboard speaker at hand?
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642068
No, only a LED to display power.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642073
1 DIMM I've tried another with the same result
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642077
This might be a stretch, but try resetting the CMOS. Is the motherboard touching the case at all directly?
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642078
Is that literally the only LED on your motherboard? Sometimes they have LEDs that are either on/off to display the status of different components. Check your manual to see if it references anything of the sort.
You may also want to check your manual and ensure that 1 DIMM is in the first slot of a (or one of the) dual channel pairs. To my knowledge, throwing a DIMM in slot 3 aint gonna do you any favors.
How many slots does your motherboard have?
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642090
Nah, the CMOS resets to defaults, if the MoBo's new (and he also changed it out for another one) CMOS won't do anything.
I know it resets to defaults, but I'm not ruling it out just because it's "brand new." That's not necessarily proper testing. It may not be likely, but I can't just ignore it because of that.
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642092
4 slots, and looking through the guide it only identifies one LED
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642096
The mobo is mounted to the case and I think touching the back panel.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642100
If it's touching the back panel(and if my understanding is correct), the motherboard is shorting out.
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642103
So, I have to remove the back panel and see if I can get a better response?
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642111
Still isn't POST.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642116
You should probably put.. them on the stand-offs?
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642117
Back panel to me is the panel the motherboard is mounted to. But that doesn't seem like that's the case.
EDIT: Are you using standoffs?
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642119
My case didn't come woth standoffs, so I just mounted it.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642123
You need standoffs. Your motherboard is shorting.
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642132
ok, so would i put the standoffs in before the mobo ormobo then standoffs? Would they go into the screw holes?
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/670228-system-wont-post/#findComment-8642157
