Hey guys, just created an account cause I need help. Its my first time building a Pc and i'm struggling to not pick the newest, most expensive 1080 (And I have no clue whats good value or not since I'm on a budget). In the future I'm planning on getting a 6600k and a 1070 G1gaming. I'll also compromise on the case with a S340 or a H440. I'll leave a PcPartPickerlink:
http://uk.pcpartpicker.com/list/GGMQd6
https://linustechtips.com/topic/669650-i-need-help-please/
1 minute ago, Ben Miller said:
Hey guys, just created an account cause I need help. Its my first time building a Pc and i'm struggling to not pick the newest, most expensive 1080 (And I have no clue whats good value or not since I'm on a budget). I'll leave a PcPartPickerlink:
You are trying to design a PC?
Here is what we need to know:
What are you using it for?
What is your overall budget?
Do you need a monitor, keyboard, etc.?
Are you planning on overclocking?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/669650-i-need-help-please/#findComment-8636485
I'm willing to spend up to £650 without windows. I'll use it for gaming (fairly casual), i've got a monitor and mouse and i might overclock slightly in the future.
https://linustechtips.com/topic/669650-i-need-help-please/#findComment-8636497
PCPartPicker part list: http://uk.pcpartpicker.com/list/bZMNzM
Price breakdown by merchant: http://uk.pcpartpicker.com/list/bZMNzM/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (£174.99 @ Amazon UK)
Motherboard: MSI H110M PRO-D Micro ATX LGA1151 Motherboard  (£45.76 @ More Computers)
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory  (£33.99 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£42.99 @ Amazon UK)
Video Card: Zotac GeForce GTX 1060 3GB 3GB Mini Video Card  (£188.99 @ Scan.co.uk)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  (£36.99 @ Ebuyer)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  (£64.98 @ YoYoTech)
Total: £588.69
Generated by PCPartPicker 2016-10-01 21:36 BST+0100
Solitaire.
https://linustechtips.com/topic/669650-i-need-help-please/#findComment-8636498
In that case I recommend you this:
PCPartPicker part list: http://uk.pcpartpicker.com/list/GYxMCy
Price breakdown by merchant: http://uk.pcpartpicker.com/list/GYxMCy/by_merchant/
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  (£56.99 @ Amazon UK)
Total: £645.68
Generated by PCPartPicker 2016-10-01 21:37 BST+0100
You will not be able to overclock in the future, but this should run most games well at 1080p
Solitaire.
https://linustechtips.com/topic/669650-i-need-help-please/#findComment-8636502
Total: £588.69
Thanks I'll consider your build
https://linustechtips.com/topic/669650-i-need-help-please/#findComment-8636504
CPU:R7 5800X    Motherboard: asrock x470 taichi ultimate   RAM: 32GB G.Skill Ripjaws-V 2X16GB    GPU: Gigabyte GTX1080TI gaming oc 11g   Case: Corsair 600Q Storage: 1TB Samsung 870(boot), samsung 850evo 500GB, 2TB Corsair MX500, samsung 2TB 970 evo plus, WD 5TB black    PSU: Corsair AX860    CPU cooling: Corsair H105
https://linustechtips.com/topic/669650-i-need-help-please/#findComment-8636520
9 minutes ago, PCNoobie said:
I see what u mean by its unbalanced but i'm trying to get as good quality as i can afford to last as long as possible, (apart from the cpu, fans, gpu which i can upgrade in the future).
https://linustechtips.com/topic/669650-i-need-help-please/#findComment-8636538
