Hi,
I feel dumb to ask this question since I know how to build a pc but..... Should I get this cable https://www.amazon.fr/JMT-Serial-Splitter-adaptateur-dalimentation/dp/B00E1VOKQO/ref=lp_430312031_1_7?s=computers&ie=UTF8&qid=1475312487&sr=1-7 for this HD https://www.amazon.fr/gp/product/B005T3GRNW/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1 to conect it to my motherboard
Thanks alot!:)
https://linustechtips.com/topic/669408-hhd-cable-question/
Nope. to connect the HDD to your motherboard you only need a SATA cable.
that splitter is to convert one molex plug from your PSU to 2 SATA power, the other cable you need to make a HDD work. But your PSU should come with more than enough SATA power plugs as is.
https://linustechtips.com/topic/669408-hhd-cable-question/#findComment-8634300
Only if your putting it in an older system without sata power.
But no thats a power cable, to connect to the mobo you'll need a sata data cable.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/669408-hhd-cable-question/#findComment-8634303
Oh I didn't knew that: even this one ? https://www.amazon.com/dp/B00UVN20AO/?tag=pcpapi-20
Ok!
https://linustechtips.com/topic/669408-hhd-cable-question/#findComment-8634309
Ok!
yep, even that one! :D
https://linustechtips.com/topic/669408-hhd-cable-question/#findComment-8634311
