Yes it will work but the CPU you pairing it with may bottleneck a 1060 :P (if it's a one of the lower clocked i5s-or should I say all i5s as they aren't great anymore, i3, pentiums ect.)
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/669121-help/#findComment-8631138
not all i5's, if he has a 4690 or a 4690k it probably wouldn't bottleneck it...just saying.
Main PC(no name yet): CPU-AMD Ryzen 7 1700, MOBO-ASRock AB350 K4, RAM-16gb G.Skill 3000MHz, GPU-Asus Strix GTX960 2gb, CPU Cooler-Stock Cooler rn, Storage-SanDisk 512gb SSD/OCZ Agility 4 128gb SSD/2TB Toshiba, CASE-Corsair Spec-02 Redshift Edition
Laptop: HP EliteBook Folio 9470m
https://linustechtips.com/topic/669121-help/#findComment-8631180
and will it work? yes, it will
https://linustechtips.com/topic/669121-help/#findComment-8631183
"H81" Aka most likely to be a sandy bridge CPU ;)
https://linustechtips.com/topic/669121-help/#findComment-8631238
H81 is lga1150...sandybridge is lga1155...so most likely devils canyon ;)
https://linustechtips.com/topic/669121-help/#findComment-8631257
...rip me, thought h61=h81 xD
1 minute ago, Zilar said:
i have a 4460
In that case, it's probably fine ;)
https://linustechtips.com/topic/669121-help/#findComment-8631276
its fine, we all make mistakes sometimes xD
https://linustechtips.com/topic/669121-help/#findComment-8631366
