I recently made the switch from Console to PC, however I'm stuck with this old Compaq 8510p which is literal garbage. My budget IS $500.
I had a build going on pcpartpicker, but I'm not sure if it's the best for the price, and would be grateful for any help you guys could offer and am open to suggestions however staying below the budget of $500 would be great. Below is my list and if it isn't great please let me know.
http://pcpartpicker.com/list/BCPFsJ
https://linustechtips.com/topic/669049-help-with-first-build/
1 minute ago, NinJake said:
Remember to get a case, a fan to cool your cpu, and peripherals. May end up putting you a little over 500 bucks however...
What he said.
Also, replace the GPU with an MSI GeForce GTX 960, it might not be as good (I don't really know.) but the 960 is way cheaper on eBay.
Also, you will need fans for your case to cool everything down. Unless you get a case with included fans, you will need to spend about $10 - $20 on some fans.
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
https://linustechtips.com/topic/669049-help-with-first-build/#findComment-8630407
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($110.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.88 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($40.88 @ NCIX US)
Video Card: MSI Radeon RX 470 4GB Gaming X Video Card  ($199.88 @ OutletPC)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.00 @ Newegg)
Total: $439.63
Generated by PCPartPicker 2016-09-30 10:47 EDT-0400
https://linustechtips.com/topic/669049-help-with-first-build/#findComment-8630435
http://pcpartpicker.com/list/dK3MCy
try this its a build a made for a friend also making the switch, it costs the same as a ps4 pro
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/669049-help-with-first-build/#findComment-8630441
Complete with case and storage, you should get this today, and enjoy the better CPU for longer. You can later on upgrade that GPU.
Motherboard: MSI B150M PRO-VDH Micro ATX LGA1151 Motherboard  ($68.99 @ SuperBiiz)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory  ($36.98 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($67.99 @ SuperBiiz)
Video Card: Asus Radeon RX 460 2GB Dual OC Video Card  ($114.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($39.89 @ OutletPC)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($49.99 @ NCIX US)
Total: $489.81
Generated by PCPartPicker 2016-09-30 10:51 EDT-0400
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/669049-help-with-first-build/#findComment-8630448
I personally just built from micro center bundle this setup
FX 8320e with Gigabyte 970 Gaming SLI M.2 board for
134 dollars
(May want to consider the "8core")
MX300 SSD 275GB for
59 dollars
RX480 8 Gig XFX 259
(I heard the  Radeon R9 290  was going for 85 dollars recently at micro center too)
EVGA 700 PSU
53 dollars amazon price match
Case I went with  DIYPC D480-W
59 dollars on newegg
I wanted the PHANTEKS p416 for same price but no drive bays
All for about 600
Like i said though if you go to micro center you save on bundling for motherboard and processor,
and if they have the R9290 for 85 bucks your under 500
https://linustechtips.com/topic/669049-help-with-first-build/#findComment-8630507
Thanks to everyone who has replied, I do have previous computers stashed away in my basement (Dead Mobo inside, and loose solder on GPU that I got from my workplace years ago. A couple 250GB drives and fans), so a new Mobo, a CPU, a PSU, Memory, and a GPU. So that settles the rough $100 on a case, fans, and storage.
https://linustechtips.com/topic/669049-help-with-first-build/#findComment-8630688
