Custom power switch
Go to solution Solved by Factory Factory,
Modern ATX power switches are very simple. They're SPST momentary switches, and the important stuff all happens on the motherboard. There's no issue of polarity or fancy electronics or anything - any piece of metal that connects the two power switch pins will work (which is why you can start a PC with a screwdriver tip). Just solder the tail from the existing switch (assuming it's not the tail that's broken) to the new switch and you're done. If the tail is broken, pick up a cheap replacement tailed switch and steal its tail.
Where would you put it?
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630275
Just now, WowMuchName said:
prob the front panel, with some drilling. if not then just the top of the case
Can you see why the button stopped working? Unplugged or something? It might be an easy fix.
However, if you do want to use that switch, I'd assume you can just solder the two wires onto the motherboard on and off bit.
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630293
well, it actually broke a few months ago, the switch itself out of the button, so I took the switch out and put it thru a PCIe bracket (ghetto fix, but works.), and had the switch behind the case, and just pressed it. anyways, only a wire popped loose at the switch, but I think it's time for a permanent solution. i didn't even think about just soldering the wires, that would work.
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630324
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630333
https://www.amazon.com/gp/product/B00HG7HO22/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
If you want to spend 10 bucks on a solution like this. I use it for my test bench. Really useful.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630336
1 minute ago, Jorgen297 said:
your location tho
Yes, I know Harambe... God damn it.
XPS 13 9350:
i5-6200U
8GB RAM
Workstation Laptop:
i7-4720HQ
GeForce GTX 980M 4G
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630349
1 minute ago, Factory Factory said:
Oh, issue: That picture is this Adafruit switch, right? https://www.adafruit.com/products/482
That's a latching switch, not momentary. It's not suitable for an ATX power switch as-is.
ohh, kk. thanks
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630350
would this work tho? https://www.adafruit.com/products/560
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630367
1 minute ago, WowMuchName said:
Yeah, that would!
You don't have 6V in a PC for the LED, but you can try 5V. If that doesn't work, you can do what they suggest and hook up the LED to 12V along with a 470 Ohm resistor in series.
Hook up the switch to the NO (normally open) contacts.
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630385
Yeah, that would!
thnx :3
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630394
I just did a little research, you could probably hook up the button's LED onto the Power LED header directly. It *should* give 5V, but it may not be high current because there's an additional resistor on the output on the motherboard. But if it did work and it was bright enough for you, then that seems like a good solution.
Do pay attention to polarity for the LED, though. Hook it up backwards and it won't light.
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630419
thanks again!
https://linustechtips.com/topic/669044-custom-power-switch/#findComment-8630426
