18 minutes ago, oflodor2000 said:
Thanks, im definitely going to check that out
I wouldn't trust kinguin unless you are buying a LOT of OS's. Sometimes the keys don't work. I wouldn't risk it.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
https://linustechtips.com/topic/668534-first-pc-build/#findComment-8624616
Just saw that i could get an oem key from amazon too (product seller is microsoft). Would you consider that safe?
https://linustechtips.com/topic/668534-first-pc-build/#findComment-8624643
Er... yes... but you don't need to buy all items from amazon ya know. :/
Skyggeis Specs:
https://linustechtips.com/topic/668534-first-pc-build/#findComment-8627055
