My primary monitor is displayed as display 2 HELP
Teemo4Life
I need help changing monitor 2 to be monitor 1 :/
Every time I open r6 it goes onto my second monitor...
Go to set display resolution, and when you select monitor 2 it should give you option underneath "make this display primary".
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
13 minutes ago, RZeroX said:
Display settings then click on the monitor and go make this my main monitor.
I did. Still dosent work. Oh wait, I think its only for r6 since I tested it in another game. How do I go to the game files and change the display thing
You set the main display in windows, right click on desktop, screen resolution and it chould give you the option the make primary, and then all games should go to new main screen.
Like this
http://imgur.com/a/PRfpY
Like this
I did. Every other game besides rainbow six siege goes towards my main monitor that I ticked.
Well...... I searched a bit around the internet, and it seems that in R6S you can choose what monitor you want game to run on inside game's settings (under display section).
I don't own the game so can't test directly.
http://www.notebookcheck.net/fileadmin/_processed_/csm_settings3_b70a1c4c7d.jpg
