Hey lads. I think i need to reapply the thermal paste onto my heatsync for my cpu. It kind of looks like a very thin coat of dry paint at the moment. I have this syringe thing that has thermal paste in it but the paste itself is very very old. The paste says it has a use by date by 2004 (yea its really old) but my question is can i still use it? Is it one of those things where it has a use by date but it doesnt degrade in its container over time? Thanks in advance
https://linustechtips.com/topic/667939-using-old-thermal-paste/
It's probably ok to use if it still flows out easily, definitely not if it's closer to looking like play-doh. It's a cheap enough thing to just buy new and have no worries though
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/667939-using-old-thermal-paste/#findComment-8618299
It'll probably be fine if it looks nice and pastey and gray still, if it's separated don't use it.  If in doubt drop down to your local pc shop and buy a tube, it's only a couple of bucks.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/667939-using-old-thermal-paste/#findComment-8618314
5 minutes ago, SweetOh said:
Electrolube GTC10S
That's likely a silicone compound, could get much better out of the conductive metals or ceramic even for under $10 and no worry of using 10yr+ old paste
EDIT: never mind on the silicone part, but the last part stands
https://linustechtips.com/topic/667939-using-old-thermal-paste/#findComment-8618336
Im not that much of a brain on this subject matter sorry, so it will work okay? I think its really needed becasue my cpu is running at 90-100 degrees
https://linustechtips.com/topic/667939-using-old-thermal-paste/#findComment-8618344
What cpu? If you've taken the heatsink off without replacing the thermal compound, those numbers happen
https://linustechtips.com/topic/667939-using-old-thermal-paste/#findComment-8618347
Its an old cpu i3-4130
54W TDP will probably do ok with that paste if it's not gone bad. If the paste is still good, and you've taken the heatsink off without cleaning and reapplying paste, it would definitely help.
https://linustechtips.com/topic/667939-using-old-thermal-paste/#findComment-8618370
