I have recently attempted to overclock my video card, though i have not noticed much of a difference. I've done some research and still to no avail i have not seen results. Can someone help me get this solved? I should have enough cooling to overclock it well, my specs should reflect that.
https://linustechtips.com/topic/667755-overclocking-help/
2 minutes ago, TiberiusMoon said:
. . . yes i see your card runs on 0 voltage xD
have you tried updating your drivers?
and reinstalling msi afterburner? (for the moment use the default skin)
Yes, i update my drivers all the time through the Nvidia GeForce experience. Also, I just installed msi afterburner
https://linustechtips.com/topic/667755-overclocking-help/#findComment-8616438
1 minute ago, TiberiusMoon said:
ooo wait i know, click the settings gear tick the settings that reffer to voltage control.
btw what do you use as a stress test?
I used Heaven Benchmark 4.0, but i especially notice no difference in fps when I'm playing world of warcraft too. Also, I unlocked voltage control, though i do not know how that should be adjusted
https://linustechtips.com/topic/667755-overclocking-help/#findComment-8616462
Do you have the overlay up while testing/gaming? Or on another screen? I always prefer to use evga's precision x. I like the layout and overlay a lot better. Score does seem low for an oc'd 970.
https://linustechtips.com/topic/667755-overclocking-help/#findComment-8619569
