i Have a Corsair Spec-02 and i was wanting to add some more fans, I have the stock, intake front and exhaust back, i have on top a Corsair Hydro H55, should i do that as intake or exhaust, i want to add a fan to the bottom and maybe another at the top, so i was thinking, leave stock and exhaust the 2 top (including h55) and intake on top and bottom, is that good?
My PCPartPicker - 1st Build
https://linustechtips.com/topic/667678-installing-fans/
What are your specs and load temps?
What are you adding more fans for?
https://linustechtips.com/topic/667678-installing-fans/#findComment-8615615
I would exhaust at top and back, intake at front and bottom, and set speeds higher for intake if you're using filters and want to keep dust out.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/667678-installing-fans/#findComment-8615625
I have it 6600k oc to 4.2, idle is about 28 to 34 and when running going about 38 to 45 some tunes a peak around 60, going about half load,  I have not stressed it yet,  in bios it's about 32c
https://linustechtips.com/topic/667678-installing-fans/#findComment-8615829
Those are low temps--you're fine up to 80-90c at load.
No graphics card?
https://linustechtips.com/topic/667678-installing-fans/#findComment-8615838
No graphics card?
Correct,  I don't game,  mainly just video encoding and recording,  thank u all for the help,  this is my 1st build
https://linustechtips.com/topic/667678-installing-fans/#findComment-8615856
So are you still getting fans? It doesn't seem like you need any more.
https://linustechtips.com/topic/667678-installing-fans/#findComment-8615863
Even if I plan on keeping it going about 24/7 and sometimes it can get about 80F in the room,  I was just thinking about installing a bottom and if I do that would it be ok to use my h55 as an exhaust? So I have bottom and front as intake and and top rear as exhaust
https://linustechtips.com/topic/667678-installing-fans/#findComment-8615901
Well you have enough thermal headroom to do just about anything.
I'd recommend to just leave things as is unless you really want to lighten your wallet.
https://linustechtips.com/topic/667678-installing-fans/#findComment-8615927
I already have the fans from a different project,  so I thought I would use that lol,  but thank u for setting my mind at ease if I don't go that route
https://linustechtips.com/topic/667678-installing-fans/#findComment-8615937
