So this randomly started happening today, when I had my 6970 in the first PCIE slot (as it was forever and worked perfectly), it suddenly wouldnt give a signal.
I moved it down to the 3rd slot, and now it works. Can the first PCIE slot be faulty?
I just replaced my dead PSU 2 days ago with a OCZ 850w mod 80+gold, so I doubt it's a power issue. wtf.gif
Any ideas on why this is happening?
Also, I just flashed to the latest BIOS version, and this is still happening!
Been around since the beginning of LTT & the forums, but mostly just lurk!
https://linustechtips.com/topic/667-z68-x3-gen3-pcie-problems/
Did you check the power connections? try the first slot every once in a while to see if it's back up but I doubt it really makes a difference in performance, Unless you are going for looks
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/667-z68-x3-gen3-pcie-problems/#findComment-8859
