Hey guys,
So I'm trying to design a build for the Fractal Design Node 202, and I was wondering what GPU to pick. The motherboard I'm using is the ASRock H110M (because that's all you really need to know). As you know, the height of this case (I'm pretty sure, not definite though) is 83mm
REQUIRMENTS:
Must be GTX 900 Series/Radeon R9 290 or later
Thanks again,
SCAMAZING
My System: http://pcpartpicker.com/list/9VrDZ8
What else do you need to know? :P
Congratulations! You just wasted 5 seconds of your life reading the last 73 characters!
https://linustechtips.com/topic/666811-need-help-w-sff-gpu-picking/
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
4 minutes ago, SCAMAZING said:
Hey guys,
REQUIRMENTS:
Thanks again,
SCAMAZING
you need a mini itx mobo. grab something like a 1060 or 1070
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
You need a mini-ITX motherboard. Your choice of GPU depends on your budget. You could fit a Titan XP in that case if you wanted to.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
11 minutes ago, SCAMAZING said:
Why not just get a small micro ATX case? the node 202 is rather large for ITX, and also rather expensive
And probably the blower RX 470, since blowers can be useful in a small case, although it's still a blower cooler so it's not going to get you the best cooling performance
Hey everybody who's complaining about the motherboard it's the Mini-ITX version of the H110-M + I know my GPU models well but I want something that can ACTUALLY fit.
7 minutes ago, byalexandr said:
You don't even need an SFF card. Just get whatever you want, as long it's not ridiculously large (as in height or thickness). Cards like the MSI GTX 1080 Gaming X will fit just fine. The reference Titan XP fits as well
THANK YOU!!!
THANK YOU!!!
But only buy a high end card if your monitor set up is better than 1080p 60hz
CPU is Intel Core i7 6700K
45 minutes ago, Mi26 said:
What's the CPU ? It might cause a bottleneck
My monitor is 4K 60hz so I'm using an ASUS GTX 1070 Turbo
You're going to want a 1080 for 4k, or better yet wait for the 1080ti
 I'm probably gonna play my games @ 1440p anyway
1440p doesn't scale to 2160p perfectly
If you're going to run games at a lower resolution you're going to want to run them at 1080p because that scales perfectly with 4k, which means RX 470/480 or 1060 for 1080p high settings
