I want my stereo to be able to play from either 3.5mm jack or Bluetooth, but I only have the following inputs: lightning (can be destroyed, loyal Android user), USB ( ONLY MP3 FILES essentially thumb drive port), FM radio (would like to keep working), and a CD player ( I would rather not destroy this either). Can anyone help me to finish this project?
CPU: Ryzen 7 1800X
CPU Cooler: H100i V2
RAM: Trident Z RGB 16GB 3000MHz Cl 14
Motherboard: ASUS RIG Crosshair VI Hero AM4 ATX motherboard
GPU: 980Ti
PSU: Rm1000x
Storage: Samsung PM961 512 GB m.2 Nvme sad
Storage: 7500 RPM 2 TB Seagate Barracuda Hard drive
Case: 570X RGB (White)
OS: Windows 10 Pro
https://linustechtips.com/topic/666784-stereo-help/
Just now, wrathoftheturkey said:
You're in luck, you're just in time for apple's 3.5mm - lightning adapters
Alas, unfortunately it's a male lightning.
CPU: Ryzen 7 1800X
GPU: 980Ti
PSU: Rm1000x
OS: Windows 10 Pro
https://linustechtips.com/topic/666784-stereo-help/#findComment-8606398
1 minute ago, wrathoftheturkey said:
What? How is that an input then? You mean it has the tip thing protruding out of the speaker?
It's a dock more than an "input", sorry for the confusion.
CPU: Ryzen 7 1800X
GPU: 980Ti
PSU: Rm1000x
OS: Windows 10 Pro
https://linustechtips.com/topic/666784-stereo-help/#findComment-8606410
Added pictures of boards, etc.
CPU: Ryzen 7 1800X
GPU: 980Ti
PSU: Rm1000x
OS: Windows 10 Pro
https://linustechtips.com/topic/666784-stereo-help/#findComment-8606483
Amy one else have suggestions?
CPU: Ryzen 7 1800X
GPU: 980Ti
PSU: Rm1000x
OS: Windows 10 Pro
https://linustechtips.com/topic/666784-stereo-help/#findComment-8606558
