I have a PSU that worked perfectly, before my brother sent it through courier and I suppose a person dropped it hard (really hard) AND when it reached me, it was not turning on! The PSU is corsair GS600 and it has costed me a fortune!
Is this repairable (and is out of warranty)? and please try not to suggest buying a new PSU as I can't afford to have one right now until it's the only resort..
https://linustechtips.com/topic/666152-accidentally-not-working-power-supply/
Have you tried to RMA?
The GS is probably still within warranty. When did you buy it?
i am quiet sure it's out of warranty till now
9 minutes ago, maneksameer said:
i think somewhere in november 2012...
Rip warranty
new PSU for you
7 hours ago, STRMfrmXMN said:
Rip warranty
new PSU for you
I just found an antec 500w PSU, can it be right for my PC?
config:
i7 2nd gen,
8 GB RAM
XFX HD 6950 1GB GPU
2 x 80mm fans in the case, and a samsung 21' full HD monitor
(I do think it needs some more juice, but that's my pocket limit as PSUs in India are very costly) if you got any other PSUs, please refer it to me
1 hour ago, maneksameer said:
I loved this PSU!! :/ are you sure it cannot be repaired, even if I had to pay for it
It's not a very good PSU so there's no reason to be attached to it :P
config:
i7 2nd gen,
8 GB RAM
XFX HD 6950 1GB GPU
What Antec 500W? There are hundreds.
antec vp500w... I also saw corsair vs 650 (but doesn't seem reliable) and a cooler Master B600.. which is good among them?
The B600 is the best of those.
