the 6800K will not work in a LGA 1151 socket, you will need a LGA 2011-3 (X99) motherboard for that CPU!
If you mean the 6700K tho, that cooler would do fine!
https://linustechtips.com/topic/665887-cooling-a-6800k/#findComment-8597605
1 minute ago, Scatted said:
Thank you! I will be switching the motherboard for that.
be warned though, X99 motherboards can get a bit expensive! MSI has some nice budegt friendly X99 motherboards i think.
https://linustechtips.com/topic/665887-cooling-a-6800k/#findComment-8597618
For just a bit of editing you can also stay on the Z170 and take a 6700K. Is best gaming CPU and can still do decent rendering.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/665887-cooling-a-6800k/#findComment-8597625
Yeah for now its fine. But having the option in the future is handy to have if you would run in a limit then. Many people thanked me in the past for still advising having a OCable system. It can give that 1-2 extra years of useable lifespan. Is lot cheaper then buying new. :)
PSU Tier list
https://linustechtips.com/topic/665887-cooling-a-6800k/#findComment-8597714
