I bought a new strix claw dark edition until then i had a crappy mouse now I got something more powerful :) ... It seems that the mouse "laggs" ( Sometimes is kinda like just stop working for a few seconds and then moves on like nothing hapend) I have downloaded the drivers, rebooted, played with the windows settings and drivers but nothing seems to work. I have a razer mouse pad the L one and its even worse when I use it.
Hope you guys can help me
https://linustechtips.com/topic/665581-mouse-issue/
1 minute ago, HydraGaming said:
  • Play around with polling rate and lift off distance if you haven't done that already.
  • Uninstall the software and see if that is the issue.
  • Tried different USB ports?
Tried USB ports
Did uninstall, Polling rate, lift off distance?
https://linustechtips.com/topic/665581-mouse-issue/#findComment-8594536
When I used all threads at csgo the mouse lagged too, maybe because I used all threads for something. Maybe it could be a cind of issue like this one.
https://linustechtips.com/topic/665581-mouse-issue/#findComment-8594538
14 minutes ago, FarikoAli3n said:
Why did you put this in the Tech News section?
Anyway, does it still happen when plugged into other USB ports? Have you tried completely uninstalling/reinstalling the driver software?
Other systems I've built:
https://linustechtips.com/topic/665581-mouse-issue/#findComment-8594547
3 minutes ago, FarikoAli3n said:
How can I turn them off?
You dont turn threads off, you free them from their task.
Does the issue happen while just in desktop or is it exclusive to games? If it is exclusive to games, try removing background processes and/or enabling an fps cap.
https://linustechtips.com/topic/665581-mouse-issue/#findComment-8594561
By mistake, i apologize... Yes it still happens, yes i have tried it
https://linustechtips.com/topic/665581-mouse-issue/#findComment-8594573
Please be careful where you post, Tech News isn't where to ask for help.
I moved you thread into troubleshooting.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/665581-mouse-issue/#findComment-8594579
