Motherboard and Case
Go to solution Solved by AjKawalski,
6 minutes ago, nipplesalad said:
Would a Gigabyte GA-B150-HD3P work with the Fractal Design Define R5, front port wise. I can't seem to find if the front connectors all plug in to the motherboard.
Thanks
Honestly these days you really don't have to worry about front IO compatibility anymore. Back when USB 3.0 was new there were motherboards that didn't have the port but these days it's so ubiquitous that it's a non issue. Just to be sure I did check to be sure and yes it has everything you need.
Thanks
https://linustechtips.com/topic/665572-motherboard-and-case/#findComment-8594436
so the 2 usb 2 and 2 usb 3 ports should be able to find a plug into the motherboard?
https://linustechtips.com/topic/665572-motherboard-and-case/#findComment-8594468
