I got four noctua a14 flx cooling my radiator but I find their noise level being annoying watching series and such.
It's time to get PMW fans so I can keep the noise to a minimum when not gaming...
Which fans would be the optimal 140 mm PMW fans?
Edit: would the corsair ML140 be a good option?
https://linustechtips.com/topic/665447-pmw-fans/
The Corsair are good fans and are being picked by people quite often (okay, partly because they *look* good, too). You could also try the NF A14 PWM from Noctua.
In any case, if you don't want to spend money on new fans and wasting your current ones, you could always look into DC control instead of PWM. For example you could grab a fan hub that has voltage control and that will essentially let you control your fan speed to a good degree. You could even use software like Speedfan to make curves based on your temps, to achieve a "PWM-like" setup (for this though the hub will have to connect to the motherboard).
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
https://linustechtips.com/topic/665447-pmw-fans/#findComment-8593203
Yep, speedfan is a B* to set up properly, but once you do it's simply amazing.
~ Specs bellow ~
https://linustechtips.com/topic/665447-pmw-fans/#findComment-8593228
What speed are you running the fans at? Have you tried lowering the fan speed?
https://linustechtips.com/topic/665447-pmw-fans/#findComment-8595170
Can't you control A14s instead? I got 2 A15s for my CPU cooler (plus 2xSpectre Pro 140mm, 1xNZXT OEM 200mm) and loudest fans are my PSU and GPU under load. At ide its still PSU. At low load (atm) one of A15s isn't spinning and other spins about 250rpm.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/665447-pmw-fans/#findComment-8597601
