im using MSI afterburner to change the speed but it goes back upto 100 on its on. Auto is off obviously. My fan curve should be active but its not following it or something
My gpu is running 30' which means the fans should be off.....but its running close to 4000 rpm which is so loud. Tried Wattman its not following commands
XFX RS Rx 470 Triple X
https://linustechtips.com/topic/665446-how-do-i-turn-down-gpu-fan-speed/
try installing newest bios update and then do some investigation in bios if there is not something :)
If that doesnt help look how to reset GPU bios to factory settings, that should help.
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
How do i update bios?
What mobo do you have?
b85m pro4
1 minute ago, Teemo4Life said:
mistake
Yeah. In the crimson driver you have a checkbox that manually overrides fan modes. It causes problems for any application you use to control the fan speed. So make sure Overdrive is enabled.
Then Afterburner is crappy anyway and has unclear buttons for enabling manual control of fans. You have to make sure it's set to run your profile.
Tell me the crimson driver checkbox thing
Where is it located?
8 minutes ago, Teemo4Life said:
b85m pro4
http://www.asrock.com/mb/Intel/B85M Pro4/?cat=Download&os=BIOS
and look on google how to install bios on that mobo :)  download only the latest version ofcourse
i have already tried and wasent bothered cause its different to downloading eg gpu drivers
okey then if that doesnt help look on google: reseting GPU bios to stock bios
Just now, MadG4mer said:
Do you even have the AMD Radeon Software on your PC? Is you do, have you set the OverDrive on?
What do u mean overdrive? The other app?? I downloaded it and it says I dont have an AMD cpu...
