Hello everyone!! I hope you're having a amazing week and day i do not know you, but i love ya!  :D Sooo to business i'm building a AMD build here are the specs i'm going for>> :
Processor:AMD FD8350FRHKBOX FX-8350 FX-Series 8-Core Black Edition
MotherBoard:ASUS SABERTOOTH 990FX
Ram:Corsair XMS3 16GB (2x8GB) DDR3 1333 MHz
GPU: Invidia GT8800 (upgrading to Gtx 760 overclocked version) or 7970 in the future still deciding on that)
PSU:Cooler Master Silent Pro M2 - 720W 80 PLUS (Modular)
Cpu cooler: i can't use water cooling due to the fact that here in Dominican republic the electricity isn't consistent and i have to use a power inverter with 4 car battery''s and it will just drain all the power from them, i need a good fan i was thinking about the
Cooler Master Hyper 212 EVO but will it performance be good when i'm overclocking the 8350? i don't want it catching on fire or anything :3, and the case is a dell case i have stored up, i was going to buy a HAF 912 but my budget doesn't cover it.
SSD: Kingston Digital 120GB
HardDrive: 1tb
CD thingy-ma-bob:Something Cheap
Ps: i need help deciding the Fan that will keep my system cool any suggestions please reply will be looking forward thanks for reading <3  :D <3   :wub:   :wub:   :wub:   :wub:   :D   :D   :D
https://linustechtips.com/topic/66507-help-with-amd-build/
From my reply to your other post:
You're not going to get a lot of cooling from a shitty dell case. Lower your budget somewhere, preferably by downgrading your blueray drive to a regular cheap 20 dollar cd/dvd drive. You could also do with downgrading your PSU as well, you don't need that much wattage.. Later down the line you can add a streaming device to your TV, such as a chromecast/rasp pi/roku and stream your local media from your computer by downloading the movies.
        Praise Duarte!
https://linustechtips.com/topic/66507-help-with-amd-build/#findComment-909000
As for this situation, get an FX 8320 and buy a 7970. The 760 is crap for the money. Also, a shitty Dell case will get you nowhere. Get something cheap and good, like a Fractal Design Core 3000 or Zalman Z9.
https://linustechtips.com/topic/66507-help-with-amd-build/#findComment-909023
Like @Mauri said, get a legit case and lower the budget in other places to make that happen. Also you could cool it with the amount of faces everywhere and post in the correct area the first time and do not repost.
My rigs
Desktop CPU: Intel Xeon E5-1680 v2 @ 4.4GHz cooled by a Corsair H105 | Motherboard: Asus Sabertooth X79 | RAM: 32GB G.Skill Sniper DDR3 1600 | GPU: EVGA RTX 3080 SC3 Ultra Gaming | SSD: Samsung 860 EVO 1TB + Crutial M500 240GB + Samsung 840 120GB | HDD: Seagate Barracuda 2TB 7200RPM + WB Black 4TB 7200RPM | Case: Fractal Design Meshify C | Mouse: Logitech G402 & MX Master | Keyboard: Poker II  MX Blue & Leopold 10-key pad Box Royals | Monitor: LG 34UB88-P | Audio: Audio-Technica ATH-M50 + FiiO E5 DAC + Rode NT-USB Mini
Laptop Lenovo Yoga 720 4k Touch
https://linustechtips.com/topic/66507-help-with-amd-build/#findComment-909024
Sorry for that haha super sorry Junior i might just save up a bit more money and buy the HAF 912 from coolmaster but still confused on the 212 EVO will it give me good performance when i'm overclocking?
The 212 EVO is a good budget cooler. You may be able to get to around 4.2GHz with it depending on if the processor can go that high. Stay under 75C and you will be fine. And please click quote when asking something. We will only get a notification then.
https://linustechtips.com/topic/66507-help-with-amd-build/#findComment-909034
We could use more details like where you're shopping from, your budget, and what you're using the system for. Your build can be improved.
Please read: https://linustechtips.com/main/topic/3061-build-plan-thread-reccomendations-please-read-before-posting/
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/66507-help-with-amd-build/#findComment-909115
