does this mobo have a built in wifi adapter as I cannot connect my PC via Ethernet as my router is to far away . And I need to know wether or not to buy a pci adapter
http://uk.gigabyte.com/products/product-page.aspx?pid=3996#ov
AMD FX-8350 II ASUS R9-20x DCU2 TOP II Fractal Design R4 II Samsung 840 Evo 250gb SSD II Gigabyte 990FXA UD-3 II 8GB Corsair XMS II Cooler Master Seidon 120mm II ACER H236HL Monitor II Corsair K70 II Razer Deathadder II Kinect II
Go check out my Build Log for my "Home Made Gaming POD"
http://linustechtips.com/main/topic/83872-home-made-gaming-pod-build-log/
https://linustechtips.com/topic/66504-motherboard-help/
no it doesn't. it would be listed in the specification. Motherboards with WiFi will have gold connectors where the external antenna  can be connected.
Build Log: Monochrome
CPU: Intel Core i5-4670K | Motherboard: Gigabyte GA-Z87MX-D3H | Graphics Card: Asus HD 7970 DirectCU II | RAM: Corsair Vengeance Pro 8GB | PSU: Corsair CXM 600 | Storage: OCZ Vertex 4 128GB,2 Seagate Baracuda 3TB | Case: Corsair 350D Window
https://linustechtips.com/topic/66504-motherboard-help/#findComment-908935
Just check the manual or the specs on the website. It would be listed there if it did.
If not, you have a few options:
1. USB wireless dongle (easiest option)
2. PCIe wireless card
3. Homeplug or powerline ethernet adapters
Choose which ever one suits you the most.
https://linustechtips.com/topic/66504-motherboard-help/#findComment-908954
Do you know any black pci wifi cards because as I am going for black build with white lighting , and I don't want an ugly green pcb showing
https://linustechtips.com/topic/66504-motherboard-help/#findComment-908958
I have this wifi dongle , will it be adequate ?
https://linustechtips.com/topic/66504-motherboard-help/#findComment-908971
It'll work, but won't be as fast as other ones. Why can't you run a ethernet cable through your house<
Because it's like 25 metres away
https://linustechtips.com/topic/66504-motherboard-help/#findComment-909162
https://linustechtips.com/topic/66504-motherboard-help/#findComment-909166
Can't you link me just one ? As I wouldn't need two
Yes you kinda would need two; as one is the transimitter and the other one is the reciever :D
RIG-Processor: Intel core i7 3770k @4.4GHz,Mobo: MSI Z77-G43,GPU:Gigabyte GTX 770, RAM:16 GB G-skill sniper f3,SSD: Corsair Force f3 240gb,HDD: Seagate baracuda 1TB,Cooler:CM Hyper 212 evo, Case: Sharkoon T28 Blue
Peripherals- Monitor: Samsung S24B300, Keyboard: Razer Blackwidow, Mouse: Razer Abyssus, Headphones: Razer Megalodon, Mousepad: Razer Goliathus Alpha, Webcam: Logitech C270,Pad:Logitech F710, Sp: Philips generic ones
#KILLEDMYWIFE #MAKEBOMBS
https://linustechtips.com/topic/66504-motherboard-help/#findComment-909199
Derp I thought it just received from your router ?
https://linustechtips.com/topic/66504-motherboard-help/#findComment-909217
Back from the dead....
https://linustechtips.com/topic/66504-motherboard-help/#findComment-909361
you connect it to your router with a utp cable
https://linustechtips.com/topic/66504-motherboard-help/#findComment-911816
Nope but you could go powerline, they offer not a bad speed
CPU:Intel i7 2700k OC @4.9Ghz cooled by custom water loop with xpsc dual240 rads, xpsc block and 750 pump/res|Ram:G-Skill RipJaw X 32GB 1866Mhz|Case: Corsair 750D|Motherboard:Asus Sabertooth Z77| Hard drive: 240GB Kingston SSD, Seagate 2TB, 1TB Hitachi |GPU: EVGA GTX 770 SC cooled by custom water loop with xpsc gtx 770 block|PSU: Corsair HX750|Monitor: LG 27 inch IPS LED Cinema| Sound Card: Creative Fatal1ty X-FI professional| Build log:
https://linustechtips.com/main/topic/64792-just-finished-off-first-watercooled-rig/
https://linustechtips.com/topic/66504-motherboard-help/#findComment-917188
