Need serious advice.
So hey guys i'm planning on getting a 144hz monitor my original plan was to get the Asus PG248Q but the VG248QE is now on sale for about 209USD(It is originally price at 271USD if not on sale)  in one of the stores here if i go with the VG248QE i could buy it now as in right now but if would go with the PG248Q i would wait around 2-3mos to get it. So i just wanted some advice if i should just go with the VG248QE and what benefits would i get with the PG248Q?
PC: CPU: Ryzen 5 5600X @ Curve optimzer -25,  Cooler: Noctua NH-D15 Chromax.Black, Motherboard: Asus Rog Strix B500-F Gaming WiFi II, GPU: Sapphire Nitro+ RX 7800XT @ Stock , RAM: G.Skill Trident Z RGB 2x16GB DDR4 3600Mhz CL18, HDD: Western Digital Caviar Black 2TB, SSD: Samsung 850 Evo 250GB | Team Group MP33 1TB NVME, Case: NZXT H7 Flow Black, PSU: NZXT C1200  I Peripherals: Keyboard: Ducky Shine 6 RGB Special Edition, Mouse: Razer Orochi V2, Headset: Philips SHP9500, Mousepad: Glorious Stealth Extended I Laptop: MSI GS63VR Stealth Pro CPU: i7-6700HQ@ 2.6ghz, GPU: GTX 1060, Memory: 16GB DDR4 2400Mhz, HDD: 1TB+128GB SSD
https://linustechtips.com/topic/664835-need-serious-advice/
Well the PG248Q has G-Sync so if you wanted to take advantage of that go for it, otherwise get the other one.
https://linustechtips.com/topic/664835-need-serious-advice/#findComment-8586586
Well yes i really wanted to take advantage of the G-sync cause i don't really want to experience screen tearing while im playing especially when i'm playing fps games like CS:GO.
https://linustechtips.com/topic/664835-need-serious-advice/#findComment-8586596
I'd wait if a functioning monitor is on hand, g sync is good stuff
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/664835-need-serious-advice/#findComment-8586621
What do you mean by a functioning monitor is on hand?
https://linustechtips.com/topic/664835-need-serious-advice/#findComment-8586623
I mean if you have a monitor that you can use until you can get the g-sync one, then I'd use that because g-sync/free sync makes for a better gaming experience, at least imo
desktop
HTPC
https://linustechtips.com/topic/664835-need-serious-advice/#findComment-8586640
Oh i see. Yes i still have a good monitor to play on. Right now i'm playing on my BenQ RL2455HM it's only 60hz and 1ms gtg. But it can do the job until i have enough money to get the PG248Q
https://linustechtips.com/topic/664835-need-serious-advice/#findComment-8586645
