Just now, SysAdminInTraining said:
They both have everything in the headset... As far as I am aware. All the audio drivers and processors are in the headset itself. Only thing the G933 is going to have is a dongle to transmit the signal to the headset.
thanks friend I was just wondering because I have a good sound card hehe xD
https://linustechtips.com/topic/664829-help/#findComment-8586513
There MIGHT be degradation of sending an audio signal via wireless as opposed to a wired connection. Less interference. I would honestly stay away from wireless headsets if you are an audiophile. I have yet to see a perfect WIRELESS headset with no static for under $500.
https://linustechtips.com/topic/664829-help/#findComment-8586519
i want to buy this headset because the cost 100 dollars and want to take dat risk
btw thx for your help it is appreciated
https://linustechtips.com/topic/664829-help/#findComment-8588803
