whenever i play gta 5 lately i get such a choppy framerate even on the lowest of settings and at 800x600 i get under playable framerate i tryed using clock blocker that why the gpu clock speed is pegged at 1040 its stock speed but still it just keeps bouncing the usage all around and never steady i did have my friends gtx 960 in it for a couple days but i already uninstalled the drivers to it and i had beta drivers from and so i unistalled those and got the previous version that i know worked and still nothing playable and i know i can get high setting at 60 and something strange i noticed is that gta said i would use only a little over a gb of vram on lowest of low settings but it slowly rose to above 3.2gb
specs
mobo) ga-990fxa-ud3 rev 4.0
cpu) fx 8320e(over clocked to 4.4ghz stable)
gpu) saphire rx 380x
10 gb of ram
650 watt psu
https://linustechtips.com/topic/664800-plz-help/
31 minutes ago, Thatguy676 said:
Is every game like that? did you try using a different GPU or PCI-e slot?
https://linustechtips.com/topic/664800-plz-help/#findComment-8586249
2 minutes ago, Thatguy676 said:
Just gta and I haven't tried a second slot
Try some older drivers potentially, if it's only that game moving the slot won't matter
https://linustechtips.com/topic/664800-plz-help/#findComment-8591311
