I've recently got all these entries stacked up on my boot options menu called EFI Shell on my motherboard. How do I get rid of these entries? i got about 6-8 entries i think at the moment from using BCD Re-create/repair boot files and when i had linux on my PC at the time. Can anyone help me? Thanks!
https://linustechtips.com/topic/664713-efi-shell-entryhow-to-remove-them/
Mmmm, the only way I can think of if they are related to previous installs is to create a Linux live boot usb. From there you can mount your boot partition in gparted and delete the directories of the other boot files. At least, that's what I did to get rid of my GRUB files after I removed Linux from my dual boot. Are you by chance using an MSI motherboard?
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
Quote
Yea actually, A H81M-P33 motherboard. When i uninstalled linux, i used bcd to repair the boot, than i deleted the linux partition.
EDIT*
I use an MSI H81M-P33 motherboard.
Download the archlinux image and stick it on a flash drive, there is an option to drop to UEFI shell 2.0
I haven't had much luck with the Tianocore repo, but I think that is what many other products use under the hood.
here are two popular alternatives found on stack overflow (I haven't tried them)
https://en.altlinux.org/Rescue
http://www.rodsbooks.com/refind
