Not sure how many Mac users are here, so this is probably a shot in the dark.  A co-worker asked me to repair his MacBook Pro (2011, 15").  Failed (failing?) hard drive.  As typical with a lot of people, his last backup is several months old.  I said I'd see what I can salvage.  Booted his machine from a DiskWarrior 5 USB stick and let it run.  It flew through steps 1-4, and then on step 5 (locating directory data); it's been running for almost 2 days, and says, "speed reduced by disk malfunction:" and a number.  Not having used DiskWarrior in over a decade, I had to look that up...apparently the number of errors it's encountered.  Well, said number just past 1 million (as in 1 followed by six zeros - 1000000!).  I could hear the drive clunking loudly as yesterday, so I figured it was on its deathbed.   Knowing the drive is pretty much hosed, is it worth letting DW keep running, or should I just throw in the towel, drop in the new HDD, install a fresh copy of Sierra, and kindly remind the owner to backup his machine more?
On a side-note, prior to running DW, I did try imaging the drive with dd in Terminal (my usual data recovery tactic)...no dice.  Just kept filling my console with I/O errors, hence why I moved on to trying DiskWarrior.
"VictoryGin"
Case: Define R6-S, Black | PSU: Corsair RM1000x, Custom CableMod Cables | Mobo: Asus ROG Zenith Extreme X399 | CPU: Threadripper 1950X | Cooling: Enermax Liqtech TR4 360mm AIO with Noctua NF-F12's | RAM: 64GB (8x8GB) G.SKILL Flare X DDR4-2400 | GPUs: AMD Radeon Vega Frontier Edition; NVIDIA Quadro P400 | Storage: 3x Intel 760p 128GB NVMe RAID-0 | I/O Cards: Blackmagic Intensity Pro, Mellanox ConnectX-3 Pro EN 40GbE NIC, StarTech FireWire, StarTech Serial/Parallel  | Monitors: 3x 30” First Semi F301GD @ 2560x1600, 60Hz; 50" Avera 49EQX20 @ 3840x2160, 60 Hz | Keyboard: Black/Gray Unicomp Classic | Mouse: Logitech MX Master 2S | OS: Windows 10 Enterprise LTSB 2016
https://linustechtips.com/topic/664622-diskwarrior-help/
13 minutes ago, Electronics Wizardy said:
I personally use ddresuce, but its about the same thing
It could take a week as it will slowly try to get the data.
If you care about the data, don't touch it, else buy a new drive.
Yeah, he said that at-most he'll lose a few pictures; but nothing too huge.  I'll see how it does in the morning.  I can't even tell if the drive is still functional at all since I don't hear it seeking.
I know he sorta wants his machine back, so I'll probably can it in the morning, replace the drive, and then let a spare tower take a DD image, and then save what I can from the image, since at this point, diskutil doesn't even know what to make of the drive.
"VictoryGin"
https://linustechtips.com/topic/664622-diskwarrior-help/#findComment-8584235
use ddrescue, its made for this, it also shows progress.
https://linustechtips.com/topic/664622-diskwarrior-help/#findComment-8584257
I shall do that.  Thank you for the tip!
"VictoryGin"
https://linustechtips.com/topic/664622-diskwarrior-help/#findComment-8584263
