Hey guys, since my last post I have been deciding between two laptops, not the strix and the other asus one, but the razer blade and razer blade stealth plus the core. I've been really deciding and thinking about the two, but I still haven't been able to come to a conclusion of which one to choose.
The blade stealth has a good battery life and is good for just browsing the web and playing minor games. With the addition of the core, I can be able to play games, but I'm limited to where I have an outlet or the needed space.
The blade has a 1060 in it, allowing me to play games with it when I need to, but the battery life is about 5 hours compared to the advertised 9 of the stealth. It's a bit heavier, louder, hotter, and thicker than the stealth, and is 100 dollars more expensive than the combo of the stealth and core, including the $100 off the core when purchasing the stealth.
Thanks, I could seriously use your help, and I'm still saving up enough money to buy any of them, though I'm closing on in affording the stealth.
  • CPU
    Intel I-7 6700
  • Motherboard
    Msi Z270i Pro Gaming Carbon AC
  • RAM
    16 GB Crucial
  • GPU
    Msi 4gb GTX 960
  • Case
    Corsair 380t
  • Storage
    Seagate FireCuda 1TB
  • PSU
    Random Antec 500w from 2010
  • Display(s)
    Asus VS278
  • Cooling
    Exhaust: LTT NF-F12 Intake: Thermaltake Riing 140mm Orange Heatsink:corsair H75
  • Keyboard
    Logitech G105
  • Sound
    Onkyo 5.1 surround Theater Speakers
  • Operating System
    Windows 10
https://linustechtips.com/topic/664134-blade-or-stealth/
You should get the stealth if you don't need to game often outside your house
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
https://linustechtips.com/topic/664134-blade-or-stealth/#findComment-8579388
i would personally go for the stealth, mostly for the core compatibility
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/664134-blade-or-stealth/#findComment-8579394
Make sure to take note of what I said in the original post, I want to play games on the go.
  • CPU
    Intel I-7 6700
  • Motherboard
  • RAM
    16 GB Crucial
  • GPU
    Msi 4gb GTX 960
  • Case
    Corsair 380t
  • Storage
  • PSU
  • Display(s)
    Asus VS278
  • Cooling
  • Keyboard
    Logitech G105
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/664134-blade-or-stealth/#findComment-8579399
Well then there's the answer I'll give you, get the blade
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/664134-blade-or-stealth/#findComment-8579435
Blade 14 - overheats due to the absurd components in such a chassis, runs at 60+dB meaning that it's as loud as a vacuum cleaner (I'm not exaggerating), Razer customer support is VERY bad - they won't help you at all. The keyboard is poor, the speakers are laughable and the resolution creates scaling issues in most games. - Bad product
Blade Stealth - runs extremely hot (90*C) and quite noisy - has very poor battery life due to the screen, 9 hours are not even possible on this machine - 6 at most. The CPU inside bottlenecks the 960 quite badly as it's a low-power dual-core with HT - it's slower than a desktop i3 due to the 15W TDP limit not allowing it to hold it's Turbo clock. - Keyboard is even worse, you have no key travel and it's very mushy, screen resolution makes even windows have scaling issues, overall - worse product.
My advice - either get a powerful ultrabook like the XPS 15 or UX501VW or forget about small and powerful and get a XPS 13 or UX305
Feel free to consult @D2ultima for a proper Pascal gaming laptop from Clevo.
Also forget about eGPU - it's not good at the moment.
https://linustechtips.com/topic/664134-blade-or-stealth/#findComment-8580338
All of Razer's laptops are trash. Overpriced trash. Don't even bother with any of them.
If you want super thin and light and able to play games, it isn't happening. Especially not with Pascal.
The thinnest machines you're going to get that are directly capable of holding a 1060 in it that I've seen thus far, are MSI's GS63VR and the Clevo P650RP6. The GS43VR, with proper repastes and fan control can do it, but the heatsink layout is dangerous to the ports (HDMI, USB on the side), the wifi card and its slot, and it's close to the PCH which is passively cooled on the system. It's a disaster of a layout, and I do not recommend it at all.
Note that while I have seen GS63VRs holding their temperatures with proper paste jobs using good paste, I don't know their internal layout, and thus I don't know if there's any danger to the other internal parts like the GS43VR has.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/664134-blade-or-stealth/#findComment-8580358
