What is a cheap yet fairly reliable hard drive that's not going to die on me after like a year of use? I would like for it to be at least 2tb and maybe no more than $80. It doesn't have to be name brand as long as it's reliable and stable. I prefer 7200RPM and above so it has fairly good speeds as well.
https://linustechtips.com/topic/664065-storage-drive/
Just now, mok said:
partial truth actually.
i cant seem to find WD Blue in a 2tb version
Yeah I can't find it either. I would go with a 1tb but I already have a 1tb and I'm looking for something to replace it but I also want more storage space on top of it.
https://linustechtips.com/topic/664065-storage-drive/#findComment-8578547
All hd's are about the same. Just get what ever cheap 2tb your find and make sure you have backups.
5400 vs 7200 doesn't make a big difference.
https://linustechtips.com/topic/664065-storage-drive/#findComment-8578624
I agree ,
also i just re-read OP's post
I would strongly suggest WD Green 2tb, bought it for my brother and he uses it in his HTPC as a file server for plex
been working for more than a year now
Photography / Finance / Gaming
https://linustechtips.com/topic/664065-storage-drive/#findComment-8578757
why not buy a second 1TB and stripe them together?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/664065-storage-drive/#findComment-8578763
