Hey,
I just transplantedd my PC into a new case and I'm going though some problems. I have checked all the cables , my fans are spinning my GeForce gtx960 is working (the lights are on) but on there is  nothing showing up on the screen! Any idea on what's probably going on?
Thanks
https://linustechtips.com/topic/663934-pc-does-not-post/
Could be almost anything in the system, double check the connections, make sure everything is plugged in right.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/663934-pc-does-not-post/#findComment-8576877
try booting off of integrated graphics if possible. GPU could possibly be an issue. Play around with the ram; take 1 stick and try it in dimm 1, then dimm2, so on, then repeat with the other stick.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/663934-pc-does-not-post/#findComment-8576897
Just now, crashahotrod said:
A ram issue would be accompanied by a constant beeping noise of the buzzer.
not if there isnt a motherboard speaker.
https://linustechtips.com/topic/663934-pc-does-not-post/#findComment-8576902
If your motherboard has on board graphics try that the drivers for your video card may not be installed.
That wouldn't cause it to not post windows will pick it up as a basic display adapter and provide drivers for it, as well as most linux versions.
https://linustechtips.com/topic/663934-pc-does-not-post/#findComment-8576904
Just now, stavros959 said:
Oooohhh sh!t!!! It worked ! Turns out a ram module wasn't installed correctly...Thank you SO much! For a sec I thought I bricked the system xD
Good to hear it! Double check in your BIOS to make sure everything else is detected and working properly too just as a precaution.
https://linustechtips.com/topic/663934-pc-does-not-post/#findComment-8576921
2 minutes ago, crashahotrod said:
Oh gosh an incorrectly installed ram module. Brings back memories to my pc repair class where someone did that and caught the system on fire... not a good day
If you hit the quote button (little arrow at the bottomof a comment) the person will get a notification, and it is helpful to keep track about who is commenting to who.
https://linustechtips.com/topic/663934-pc-does-not-post/#findComment-8576945
