My GPU is either 85°C running with 99% FAN Speed or 87°C running with 77% FAN Speed. Maybe I need to replace the thermal paste.
CPU: Ryzen 7 5800X | MOBO: Gigabyte B550 Vision D | RAM: Crucial Ballistix RGB 32GB 3600MHz | GPU: Gigabyte RTX 3070 Vision D | PSU: Seasonic Focus+ Gold 750W
https://linustechtips.com/topic/663235-weird-gpu-temps/
99% the TP is not reason for this. How' s your airflow and cpu temps?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/663235-weird-gpu-temps/#findComment-8569371
GPU may be going bad.
https://linustechtips.com/topic/663235-weird-gpu-temps/#findComment-8569373
3 minutes ago, dannolt said:
GPU: Sapphire R9 280x Dual-X
" what is your case, what is your GPU, what kind of cooler is on your GPU, and how many intake/exhast fans do you have in that case? "
I need the answer to all of those questions. not just one of them.
https://linustechtips.com/topic/663235-weird-gpu-temps/#findComment-8569378
I had the same card, temps were decent for the first 2 years and then they were in the 80s under load.
CPU - i7-10700K, MB -MSI Z490 Gaming PlusRAM-Corsair Vengeance Pro 3200MHz, GPU - MSI GeForce RTX 3070 GAMING X TRIO, PSU - EVGA 650w Supernova G2 80+ GoldStorage - Samsung 970 EVO 500 GB ,WD 3x Samsung 860 EVO 500GB, Cooler- Noctua NH-D15S, CASE Fractal Meshify 2 Compact
https://linustechtips.com/topic/663235-weird-gpu-temps/#findComment-8569788
