My friend brought me a P5VD1-X to fix. And I tried everything. I've tried 3 sets of RAM, used different slots, used PCI, PCIe as well as AGP graphics cards, swapped CPU's around, reset the CMOS a couple of times, disconnected everything, I've tried everything. But it just doesn't produce any video. I'm pretty sure the motherboard and the BIOS are fine since they produce a beep code whenever no RAM/GPU is installed. There are no dead caps, no bent pins, the battery is at an acceptable 2.87V. My friend told me that this happened after he installed a new CPU and hard drive (the CPU is compatible according to ASUS). I really don't know what to do now. Any help is appreciated! :D
i7 6700k - 32GB DDR4-2133 - GTX 980
https://linustechtips.com/topic/662840-kinda-strange-problem/
i am honestly stumped. Another thing i could think of is just plugging in the mobo, and wearing full length rubber gloves (the kind you use for washing dishes or electricians gloves if you have them) and testing everything with an mulitmeter
https://linustechtips.com/topic/662840-kinda-strange-problem/#findComment-8564770
There's no video. But it produces beep codes whenever I trigger a certain error. So the BIOS and the CPU are fine. The only real problem could be the north bridge since none of the graphics cards work.
https://linustechtips.com/topic/662840-kinda-strange-problem/#findComment-8564807
i believe it may be the fact that the system ram is only running on ddr,
looking at the clock speeds for the ram it appears that the system ram is almost slower than the graphics ram,
i think this might be causing trouble because the card isnt getting what it has to display fast enough so it just doesnt work
https://linustechtips.com/topic/662840-kinda-strange-problem/#findComment-8564904
