Best air cooling?
Go to solution Solved by aisle9,
1 minute ago, Letharas said:
I dont know that yet
i do have the coolermaster nepton 140xl but idont know if that is good and fits on all cpu's
It's not, really, but it does fit just about anything within the right socket types (your CPU almost certainly is).
Air cooling doesn't get any better than the NH-D15. Right up there with it are the NH-D14, the Cryorig R1 (both variants), the beQuiet Dark Rock Pro 3 and the Phanteks TC14-PE (think I got that model number right). The next step down are the massive single-heatsink coolers like Noctua's 140mm, the Cryorig H5, the Thermalright Macho, etc. Then you get down to the smaller or slimmer coolers like the ubiquitous (and no longer worth buying) 212 EVO.
TL;DR, Noctua NH-D15 is the best of the best.
if you have a good budget, get the noctua dh-15 and get black and white fans for it. so it would total around 110 dollars usd with the cooler and fans. it can overclock to around 4.8 - just experiment with the voltage and multiplier
https://linustechtips.com/topic/662816-best-air-cooling/#findComment-8564411
Half the price of the dh-15 is just the fans might as well get a Cryorig R1 ultimate or a Dark Rock pro 3
https://linustechtips.com/topic/662816-best-air-cooling/#findComment-8564429
Or you could just get a Cryorig R1 Ultimate/Universal, same price, same cooling, looks a million times better and the universal doesn't effect RAM clearence
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/662816-best-air-cooling/#findComment-8564433
The best possible air cooling is Noctua NH-D15. As for the motherboard - get an Asus Z170-A It's a black/white style.
i7 6800K
Corsair H110i GT
Asus ROG Strix X99 Gaming
Corsair Vengeance LPX (4x4GB) 3200MHz
Samsung 850 EVO 500GB
Seagate Barracuda 3TB
R9 270X
NZXT H440 (Black/Red) 2015 Edition
EVGA SuperNOVA P2 850W
BenQ XL2411Z
https://linustechtips.com/topic/662816-best-air-cooling/#findComment-8564455
4 minutes ago, Letharas said:
What is the difference between the ultimate and universal
The Ultimate has a full sized fan and is therefore a bit quieter/cooler but the universal doesn't effect RAM clearance because of its thin 140mm fan. The default color for the universal is white and the default color for the ultimate is black but that can be changed easily
https://linustechtips.com/topic/662816-best-air-cooling/#findComment-8564463
17 minutes ago, Letharas said:
What is the best looking and best performancing air cooler?
for the intel i7 6700k
Not sure what motherboard im going to take
Black white style
Here's an important question that no one's asking: what kind of case are you buying/do you have?
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/662816-best-air-cooling/#findComment-8564474
https://linustechtips.com/topic/662816-best-air-cooling/#findComment-8564719
https://linustechtips.com/topic/662816-best-air-cooling/#findComment-8564747
