HELP!!! GPU Isn't Working Properly
Go to solution Solved by Choy188,
its a common noob mistake
I just got a custom pre-built pc and when I started to play I noticed something odd the games are slow as crap then I check afterburner then it shows me that the Msi Gtx 1060 is only using 4 percent of its power and the intel graphics were doing all the work. The GPU is Being Detected by device manager. When I overclocked the GPU Had no change at all not even in Temp Or In Voltage. The only thing that seems to respond is the fans that's it.
CPU:I5-6600
GPU:MSI GTX 1060 GAMING X 6GB
RAM:8GB 2133Mhz GSKILL RIPJAWS
https://linustechtips.com/topic/662420-help-gpu-isnt-working-properly/
Reinstall the Nvidia drivers and see if that helps. Use DDU to uninstall the old drivers and install the newest from Nvidia.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
CPU:I5-6600
Did you plug in your video out into the gpu?
Main Rig:
| 13900K@6.1/4.7 w/TVB | Corsair h150i Elite LCD | Sapphire NITRO SE+ 6900XT@2710MHz | ASUS Z790 Strix-E | Corsair DDR5 Dominator Platinum 2x16GB@6200MT/s | Lian Li O11 Dynamic EVO |
My Folding Stats
is your display cord thing plugged into the mobo?
Main Rig: CPU: AMD Ryzen 7 3700x; Motherboard: Asus Prime X570-Pro ; RAM: Corsair Vengeance RGB Pro 64GB DDR4 3200 MHz ; Storage: Corsair MP600 500GB, Kioxia 2TB M.2 ; Graphics Card: EVGA RTX 3080 FTW3 Ultra ; CPU Cooler: Corsair H100i Platinum SE ; Case: Corsair 4000x White
Laptop: Dell XPS 13 9310 i7-1185G7
Phone: Samsung Galaxy Note20 Ultra
Try checking if your power supply is connected properly, that can be an issues if the builder of the machine was in a hurry to connect the cables. Just try unplugging and plugging the GPU power cable again. If that does not work. See if it is well seated in the motherboard. Also, go to NVIDIA control panel and see if it is using the graphics card at all, you should be able to change it in the settings. Hope this helps.
Just now, Doctor Luke said:
What do you mean
There are two DVI/HDMI/whatever you're using outputs, one on the motherboard IO (the vertical one), and one on the GPU (the horizontal one). Which one is your screen cable plugged into?
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
silly plug it into the gpu
if that doesnt fix it then try going into the system graphics settings
its an hdmi because I don't have a dvi dual link
Plug it into the GPU.
Just now, asapansh said:
buy an adapter or buy a new cable because you need to plug in the display into the graphics card
no dont buy a new one just unplug the HDMI from your Motherboard I/O and plug it into the HDMI on your GPU's I/O
I dont thnk he has an hdmi female on his gpu
R u kidding??? what modern GPU doesnt have HDMI
also this is quoting from MSI's website
Video Output Function
  • DisplayPort x 3
  • HDMI x 1
  • Dual-link DVI-D x 1
  • DisplayPort x 3
  • HDMI x 1
Oh lol the op said he only had dvi-d on his gpu so i didnt even look twice
  • DisplayPort x 3
  • HDMI x 1
Dude I don't care right just I need to hop on witcher 3 now with ultra settings
