USB 3 Not working..
Solved by Exonoz,
If you are using OC GENIE you may need to disable it. I had a similar problem with my MSI Z77A-G43 where my USB 3.0 ports weren't working and it was fixed by disabling the OC GENIE function.
That was the problem! The motherboard is sent back to where i bought it from, will have a new one in the start of next week. Thank u ![]()
PopsicleHustler ·
Posted in Audio0 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
