Well its not technically 2 SD Cards, its a MicroSD In a USB Adapter and a Fullsize SD Adapter with another micro in it. either way - i have both drives formatted to NTFS With no partition(Both read Unallocated in Disk management) but for some reason i cant figure out it wont let me Stripe them, they are (Essentially) the same size and have the same file system.(One is a 3.64 Gb Generic SDHC Micro inside a Dane USB Adapter And the other is 3.69 Sandisk SDHC Micro, if thats any help)
https://linustechtips.com/topic/661360-raid-0-between-two-sd-cards/
You must do it in the BIOS I believe.
18 hours ago, Modsojoy said:
According to the internet its possible to trick windows into thinking the drives are Not Removable so I'l try that route and see if it works.
Why do you want to do this though? As @manikyath said, sure, for science, neat, but what's your actual reason? The curiosity is killing me.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
On 16.09.2016 г. at 1:09 AM, Modsojoy said:
~snip~
Hi there :)
As the guys pointed out, you can't simply put two or more external or removable storage drives into a RAID array through Disk Management.
One way of doing this would be getting a card reader or a dock station that supports RAID on its own so the system would see all cards as one.
I wouldn't try to force the OS to recognize an external drive as an internal as this may lead to some issues.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
  • 3 years later...
https://www.amazon.com/MicroSD-MicroSDHC-Adapter-Converts-Cards/dp/B001RPEJA4
Found one that works for the Sony proprietary MemoryStick Pro Duo... used to use it on my PSP, worked fine...  But I have been looking for one that does the same for full size SDcard...
