Help Required Motherboard
Solved by Vadise,
Well, from these three you show, the GA-Z170N-Gaming 5 has a slightly more robust cooling solution than the other two. Gigabyte's offerings have USB-C on board, MSI's does not but it comes with two more USB ports. They all have M.2.
GA-Z170N-Gaming 5 supports up to 3333mhz of memory OC
GA-Z170N-WIFI 3200mhz
Z170I GAMING PRO AC 4200mhz
And according to ARK, your 6700k will only support up to 2133mhz in DDR4 dual channel out of the box. ( http://ark.intel.com/products/88195/Intel-Core-i7-6700K-Processor-8M-Cache-up-to-4_20-GHz )
It all depends on how much you appreciate USB type C in your rig and how hard you want to try to push your system later. In my opinion the GA-Z170N-Gaming 5 is a happy middle ground.
