Hi everyone, I am currently building a gaming computer and was wanting some feedback and suggestions on my parts list and build ideas! Please leave your feedback and ideas for the build, so I have room to decide, before I buy all the parts! :D
Parts:
NZXT S340 (Black/Blue)
MSI Z170a Gaming Pro Carbon
Samsung 750 Evo (256GB)
EVGA 750w SUPERNOVA Semi-Modular PSU
EVGA GeForce GTX 1060 FTW 6GB
16GB Kingston HyperX Ram
NZXT Kraken x61 CPU Cooler
2TB Seagate Firecuda HDD
intel i7-6700k Processor
Build Ideas:
  • Put the Kraken x61 in a push configuration in the front of the case.
  • Overclock my CPU to 4.8 GHz
https://linustechtips.com/topic/660796-nzxt-build-feedback/
Looks all good! Do you have a budget so I can make recommendations? Also, what's the purpose of this computer? Workstation or gaming? That way we can make suggestions.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
https://linustechtips.com/topic/660796-nzxt-build-feedback/#findComment-8544631
Gaming is my main purpose and $1,200 or less.
https://linustechtips.com/topic/660796-nzxt-build-feedback/#findComment-8553297
I would go with the 6600k then, because few games use hyper-threading. The only reason you would need a 6700k is I'd you were doing heavy video editing or something. I would opt for a GTX 1070 , as its pretty good for the price and is SLI compatible. What are you playing to need a X61? There are some really good air coolers out there that will probably for your needs.
Skyggeis Specs:
https://linustechtips.com/topic/660796-nzxt-build-feedback/#findComment-8555175
I am primarily streaming, gaming, and editing in heavy load applications though.
https://linustechtips.com/topic/660796-nzxt-build-feedback/#findComment-8555419
I guess you could go with the 6700k then. I would probably go for a better GPU and cut on the cooler. I don't think you'll be needing an X61.
Skyggeis Specs:
https://linustechtips.com/topic/660796-nzxt-build-feedback/#findComment-8555459
