speaker problem.
Solved by niksuto,
Hey guys! i just encountered a problem with my speakers while listening to music! the problem is that,when i was listening to music,i thought i heard someone calling my name,so i turned my volume down but.........,even after turning it down,i could listen a little bit of sound! it was fully turned down,but still i could hear the sound!my speakers brand is "creative"(if that helps). then i tried to turn off the speaker,then it stopped.
Thanks!
This happens often, means your pot doesn't cut all the signal. It's nothing to worry about, just turn off the speakers or stop the music. I have the same "problem" with my guitar amp.
