3 minutes ago, Muzzy2002 said:
I am about to place the cpu in the motherboard and I don't know if I have to press down or what I'm shit scared because this is my first build and costed quite a lot please help someone
DONT PRESS DOWN, JUST DONT YOU WILL DAMAGE THE SOCKET OR CONTACTS IF YOU DO, JUST LIGHTLY PLACE IT IN WITH THE ARROW POINTING DOWN TO THE LEFT SIDE
https://linustechtips.com/topic/660664-cpu-motherboard-help/#findComment-8542583
You don't need to press down. Just set it in and move the latch.
https://linustechtips.com/topic/660664-cpu-motherboard-help/#findComment-8542585
EDIT: The socket cover is removed differently one newer CPUs FYI, just remove it in whatever way efter you've opened the socket. You're also supposed to LINE UP THE TRIANGLES ON YOUR MOTHERBOARD AND CPU.
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
https://linustechtips.com/topic/660664-cpu-motherboard-help/#findComment-8542594
4 minutes ago, Thorimus said:
3 minutes ago, kiritoblank said:
yeah don't worry to much about the pressure needed to close the latch, it's normal
Thanks to you all I think I successfully did it :/
https://linustechtips.com/topic/660664-cpu-motherboard-help/#findComment-8542616
10/10 best way to scare a first time builder :D
CPU: R5 3600 @ 4.4 GHz
RAM: 16GB DDR4 @ 3200 MHz
GPU: RTX 2080 Super
https://linustechtips.com/topic/660664-cpu-motherboard-help/#findComment-8542624
