Are you using a genuine version of Windows?
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/65989-software-problems/#findComment-901849
Yeah..... if you want to download windows online.... you just shouldn't.
If you actually bought it legit, could be anything from your motherboard to your CPU to your drives malfunctioning. Hard to tell.
I want to download it online from the official site I still have to product key it is a legit version. Just can't find where to get a copy that isn't illegal
https://linustechtips.com/topic/65989-software-problems/#findComment-902085
http://www.w7forums.com/threads/official-windows-7-sp1-iso-image-downloads.12325/ there are some of official .iso files. I have tested one and it was legit. Remember to choose right version.
Install all windows updates, drivers and update bios before other drivers.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/65989-software-problems/#findComment-902765
