So im getting rid of it for a new one soon but my gtx 580 is idling at 56 degrees.
have never known it this high before, weird?
any thoughts?
Have lots of airflow too?
** running at stock speeds **
Intel I7 2600k @ 4.5ghz, Asetek 510 LC Xtremegear liquid cooling system, PALIT GTX 780 Super Jetstream OC, 8Gb Kingston Hyper X blu series 1600mhz, 64Gb Crucial M4 series SATA III Gaming MLC SSD, 1TB Western Digital HDD 6.0gb/s,  Asus P8z68-v Pro Motherboard, Corsair Vengance K90 Keyboard,950Watt Cyberpower PSU, Cyborg RAT 5 ,  Coolermaster CM 690II case, Dell Ultrasharp U2412M 1920 x 1200
https://linustechtips.com/topic/65928-gpu-heat-issues/
is it dusty?
Ahhhhhhhhhh it could well be....................
https://linustechtips.com/topic/65928-gpu-heat-issues/#findComment-900950
GPU is dusty, case fan died so airflow is reduced.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/65928-gpu-heat-issues/#findComment-900951
case fan died? are you referring to yourself or me lol?
https://linustechtips.com/topic/65928-gpu-heat-issues/#findComment-900967
why would I be referring to myself? my GPU's aren't idling hot. I'm talking about you and your PC.
https://linustechtips.com/topic/65928-gpu-heat-issues/#findComment-900982
Because you said case fan died, my case fans are fine
https://linustechtips.com/topic/65928-gpu-heat-issues/#findComment-901009
Then why would you assume his case fan died?
CPU: Intel Core i5 2500K | Case: Bitfenix Prodigy | Motherboard: GA-H61N-USB3 | RAM: Corsair 8GB 1333 MHz Video CardEVGA GTX 660 Superclocked 2GB DDR5
Power Supply: Corsair CX 430 | SSD: Samsung 840 120GB | HDD: 2X Seagate Barracuda 500GB 7200rpm | Monitor Asus PB238Q & Asus PB278Q
Mouse: Lenovo N50 | Keyboard: Apple Pro Keyboard | Operating Systems: Hackintosh OS X 10.8.5 & Windows 8.1
https://linustechtips.com/topic/65928-gpu-heat-issues/#findComment-901012
I wasn't assuming, I was offering possible explanations for his GPU's increased idle temps. He didn't say that he checked anything.
https://linustechtips.com/topic/65928-gpu-heat-issues/#findComment-901059
chances are its full of dust....get a can of air and blast it clean.
esp. if its a ref type cooler as they get clogged.
 either way just blast it and it will be good
Old Rig | Cpu - Intel Q6600 @ 3.5Ghz | Cooler - Cooler Master Hyper 212+ | Mobo - Asus Rampage Extreme | Ram - 8GB OCZ Gold 1600mhz | Gpu - 2x Asus DK Radeon HD 4870 1GB (Crossfire) | Psu - Corsair TX750W | Case - Thermaltake Element G
New Rig | Cpu - Intel 4770K @ 4.5Ghz | Cooler - Swiftech H220 | Mobo - Asus Z87 Deluxe | Ram - 16GB Kinston Hyper X Beast @ 2400Mhz | Gpu - Sapphire R9 290X | Ssd - Kingston Hyper X Beast 3K 240GB | Psu - Corsair HX850W | Case - Fractal Design Define R4
https://linustechtips.com/topic/65928-gpu-heat-issues/#findComment-901202
I would clean the card and reapply thermal paste if cleaning the card doesn't help.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/65928-gpu-heat-issues/#findComment-901772
