I am currently using an A8-7670k & ASUS A88X-Gamer in a Thermaltake Versa h22 case. My radiator on my Seidon 120v seems not to fit right, whats the best liquid cooler to use in this case? There is really no room at the top of the case or I would have put it up there... and with the way my motherboard is the top just barley can fit 2 fans wedged and rigged to the top as it stands. The back is pretty close to the same as I was able to put 2 screws into it and then had to put a fan into push and not pull it make it work. It was recomended trying to find a Asetek 550 Liquid cooler but there hard to find it seems.
https://linustechtips.com/topic/659056-need-advice/
just use 1 fan
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/659056-need-advice/#findComment-8523460
