best aggressive case?
Go to solution Solved by SSOB,
Why can't anybody just anwser the question instead of yelling out loud that a more simplistic case is better. Personally i would go with the elite 430
If you looked in the gpu section then you know that im making a pc for a customer which is a young teenager, i asked them what kind of case they want and they didnt know so with the parents consent i took a look around the area that the pc would be, guess what i found, a red rat 7 and a strike 7 keyboard, first one ive actually seen, its overpriced but im jealous as hell.
Anyways back to topic ive narrowed it down to a few cases and need your help picking out the one to get for this customer. Please no recommendations that arent on the list.
How about reading above before you post a case that i told you NOT TO POST, GET IT IN YOUR HEADS PLEASE!!!
bWFpbmltYWdlcy9wcm9kdWN0X2ltYWdlcy9vcmlnCoolermaster K280, ive never used this, hopefully one of you guys have used it before.
bWFpbmltYWdlcy9wcm9kdWN0X2ltYWdlcy9vcmlnCoolermaster ELITE 430, ive used this but its got a big window and bad cable routing, it would dig me a big hole
bWFpbmltYWdlcy9wcm9kdWN0X2ltYWdlcy9vcmlnCoolermaster k380, built in it once as it was on half price(thats why ive not used the first case)
bWFpbmltYWdlcy9wcm9kdWN0X2ltYWdlcy9vcmlnSharkoon VS3-S chrome USB 3.0 edition(the cheapest one and ive got a bit of experience with it)
Aerocool strike-x extreme. Im a bit on edge, its a aerocool case so you know what that means, on the other hand it might make for a joke of a review.
Listen if you care.
https://linustechtips.com/topic/65905-best-aggressive-case/
Oh God, looking at this hurts. LED fans and nonexistent front panels everywhere...
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900485
Don't get the Elite. I have it. I hate it.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900492
I know its hard but this kid is going through "that" stage, the weird one, we just have to accept it, i dont care, either way i get paid.
Listen if you care.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900493
Out of those I would take the Aerocool case. I don't think a teenager that's not building the machine himself cares too much about practicality, just the aesthetics, and it looks the best by far.
CPU: Ryzen 5 3600 @ Stock, CPU cooler: Dark Rock 4, Motherboard: MSI B450M PRO-M2 MAX, RAM: 2x8GB Crucial Ballistix DDR4 @ 3000Mhz, GPU: EVGA GTX 1080 ACX 3.0, SSD: Crucial P1 1TB M.2 + 2x120GB SSDs, Case: Corsair 110R, PSU: Corsair TX650M, OS: Windows 10 64-bit.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900494
Btw you guys dont need to care about the reset button, i wont plug it in.
Listen if you care.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900495
I went through that. That is why my first case was a Zalman Z11+
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900502
To be fully honest, all of these cases look horrible, i would say that buy clean looking case and build agressive looking system inside. :)
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900504
lol, luckily my newest personal machine was nearly a z11 then i snapped out of it and got the z9, it has a crap ton of features, id buy another z9 but i dont like it when everyone has the same case, already have two define cases(r4 and r3 but they are basically the same). I really dont like how the r4 looks, its just me, its goes againest me.
Listen if you care.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900510
dont have the money for an aggresive inside, if i did then i would get the corsair 230t, anything for the first review. I know must guys here hate them but there are some people that like them.
Listen if you care.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900518
i dont like the earocool becus the one i have is sht it realy is cuz its very very thin metal crappy plastic no drive cages or what so ever and even the power button is crap
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900520
Corsair C70.
Now what did i say about not recommending other cases, the budget is very low in this system, something like that would be pointless and unappealing for the customer, my feelings cant get involved.
Listen if you care.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900522
And i thought the sharkoon would clean slate the rest of the cases, im wrong it seems.
Listen if you care.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900530
why don't you het a nice looking case that will accommodate all of your components and look good when you have gone through this "stage", any ways the core 3000 for good looks or something alon them lines but if you want to be with "that" the last one looks the best to me.
main rig: http://uk.pcpartpicker.com/p/GFvH7P
next upgrades. h440 . 8320.  possible liquid cooling AIO
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900540
Exactly. Besides, the C70 is so damn expensive. I have one, and it was worth the money, but expensive no less.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900600
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900604
Does it have to be one of these? because for £40 the nzxt source 210 is a balling case. (if you want no windows and a clean look)
for £15 more you can get a flashy case with led fans and a window...the sharkoon t9 (red, green, blue...)
both have great features and i can vouch to thier quality. if you wish I can even do a youtube review for you.
my friend has an elite 430 (I build all my friends pc's but this was his choise without me knowing) i was dissapointed, the top fans lack clearance when mouting something like a read AIO cooler, theres minimal space for cable managment, the front looks like its been designed to house a floppy drive :wacko: if you mount a fan in the window to cool a gpu it collects dust over time, the front fan is relatively noisy 9its cheap so ill let it pass) but it costs more than the nzxt 210 :unsure:
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900646
http://www.aria.co.uk/Products/Components/Cases/Midi+Tower/Corsair+Graphite+Series+230T+Compact+Mid+Tower+Case+with+Red+LED+Fans+?productId=57889
If by chance it goes on a 80% discount then maybe. Honestly i thought the case was £50 maybe $60 but £120, corsair are on drugs or thats a place holder.
Listen if you care.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900755
I'd say Zalman Z11. Not the most agressive, but much more well-known and it has the looks :D
The case is too wide due to the side vents, i was going to get it before i saw there was a size issue( its a desk with an area for a desktop to sit with vent holes so its doesnt die).
Listen if you care.
https://linustechtips.com/topic/65905-best-aggressive-case/#findComment-900765
