so i recently updated my Graphics Drivers and it seemed to mess up my Positioning (my screen of my monitor, like its edges have been cut off)
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
https://linustechtips.com/topic/658785-odd-display-positioning/
if its an NVIDIA GPU rightclick on the desktop and go to the NVIDIA controllpanel, go down to display and the change resolution and put it at whats defult for your monitor, it seems it has switched from 16:9(or 16:10) to 4:3
Builds:
https://linustechtips.com/topic/658785-odd-display-positioning/#findComment-8519514
that worked for desktop but in full screen none of my games work right even when i change the display
2) i was using 1080p just fine before the 3rd driver update
Dendrotoxin
Perripherals
https://linustechtips.com/topic/658785-odd-display-positioning/#findComment-8519561
change the resoltution in those games then :) that should do the trick, if not then restart your PC and try again, if its still broken use DDU and remove the latest drivers and reinstall them
Builds:
https://linustechtips.com/topic/658785-odd-display-positioning/#findComment-8519571
