Posted September 11, 2016 The build has 8gb of ddr3 ram and an amd athlon x4 860k Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 Theyr gonna perform quite similar to each other, but the 460 is usually less expensive and power efficiency may be almost equal. Groomlake Authority Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518511 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 460 is literally 40-50% faster Archangel (Desktop) CPU: i5 4590 GPU:Asus R9 280 3GB RAM:HyperX Beast 2x4GBPSU:SeaSonic S12G 750W Mobo:GA-H97m-HD3 Case:CM Silencio 650 Storage:1 TB WD RedCelestial (Laptop 1) CPU:i7 4720HQ GPU:GTX 860M 4GB RAM:2x4GB SK Hynix DDR3Storage: 250GB 850 EVO Model:Lenovo Y50-70Seraph (Laptop 2) CPU:i7 6700HQ GPU:GTX 970M 3GB RAM:2x8GB DDR4Storage: 256GB Samsung 951 + 1TB Toshiba HDD Model:Asus GL502VTWindows 10 is now MSX! - http://linustechtips.com/main/topic/440190-can-we-start-calling-windows-10/page-6 Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518512 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 2 minutes ago, don_svetlio said: -snip- Benchmarks shows a 7-10 fps difference tough :p. Still better. Groomlake Authority Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518521 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 Just now, VerticalDiscussions said: Benchmarks shows a 7-10 fps difference tough :p. Still better. 460 is 8% slower than a 950 in DX11 and 20% faster in DX12http://gpu.userbenchmark.com/Compare/Nvidia-GTX-950-vs-AMD-RX-460/3510vs3641 Both over 50% faster than 750 Ti Archangel (Desktop) CPU: i5 4590 GPU:Asus R9 280 3GB RAM:HyperX Beast 2x4GBPSU:SeaSonic S12G 750W Mobo:GA-H97m-HD3 Case:CM Silencio 650 Storage:1 TB WD RedCelestial (Laptop 1) CPU:i7 4720HQ GPU:GTX 860M 4GB RAM:2x4GB SK Hynix DDR3Storage: 250GB 850 EVO Model:Lenovo Y50-70Seraph (Laptop 2) CPU:i7 6700HQ GPU:GTX 970M 3GB RAM:2x8GB DDR4Storage: 256GB Samsung 951 + 1TB Toshiba HDD Model:Asus GL502VTWindows 10 is now MSX! - http://linustechtips.com/main/topic/440190-can-we-start-calling-windows-10/page-6 Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518531 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 2 minutes ago, VerticalDiscussions said: Benchmarks shows a 7-10 fps difference tough :p. Still better. DX12 bench Archangel (Desktop) CPU: i5 4590 GPU:Asus R9 280 3GB RAM:HyperX Beast 2x4GBPSU:SeaSonic S12G 750W Mobo:GA-H97m-HD3 Case:CM Silencio 650 Storage:1 TB WD RedCelestial (Laptop 1) CPU:i7 4720HQ GPU:GTX 860M 4GB RAM:2x4GB SK Hynix DDR3Storage: 250GB 850 EVO Model:Lenovo Y50-70Seraph (Laptop 2) CPU:i7 6700HQ GPU:GTX 970M 3GB RAM:2x8GB DDR4Storage: 256GB Samsung 951 + 1TB Toshiba HDD Model:Asus GL502VTWindows 10 is now MSX! - http://linustechtips.com/main/topic/440190-can-we-start-calling-windows-10/page-6 Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518543 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 Just now, don_svetlio said: -snip- Its a great gpu for gamers ! Groomlake Authority Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518545 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 Just now, VerticalDiscussions said: Its a great gpu for gamers ! Currently - 460 is the best low-power GPU. At less than 75W it beats out the 950 which needs 75-90W. 750 Ti is just a memory of a time long past. I should know, my Y50 has a 860M (750 Ti rebrand) Archangel (Desktop) CPU: i5 4590 GPU:Asus R9 280 3GB RAM:HyperX Beast 2x4GBPSU:SeaSonic S12G 750W Mobo:GA-H97m-HD3 Case:CM Silencio 650 Storage:1 TB WD RedCelestial (Laptop 1) CPU:i7 4720HQ GPU:GTX 860M 4GB RAM:2x4GB SK Hynix DDR3Storage: 250GB 850 EVO Model:Lenovo Y50-70Seraph (Laptop 2) CPU:i7 6700HQ GPU:GTX 970M 3GB RAM:2x8GB DDR4Storage: 256GB Samsung 951 + 1TB Toshiba HDD Model:Asus GL502VTWindows 10 is now MSX! - http://linustechtips.com/main/topic/440190-can-we-start-calling-windows-10/page-6 Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518554 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 470 Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518557 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 1 minute ago, Windows 10 said: -snip- Aint that like 40-50$ more over the 460? Its only a 20-30$ from the 480. Groomlake Authority Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518569 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 I would go with the RX 460 and the reasons are: -it is newer -needs less energy -in some cases less expensive -gaming should be a bit faster at 1080p -better display connectivity This is only a personal opinion and in some cases the 750ti may be better but i would still chose the rx 460 because i would use it for multimedia and not gaming. I hope it helped you a bit in choosing the card. Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518594 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 2 minutes ago, tomtony said: I would go with the RX 460 and the reasons are: -it is newer -needs less energy -in some cases less expensive -gaming should be a bit faster at 1080p -better display connectivity This is only a personal opinion and in some cases the 750ti may be better but i would still chose the rx 460 because i would use it for multimedia and not gaming. I hope it helped you a bit in choosing the card. It's actually a LOT better at 1080p - as you can see from Guru3D - it's beating the 950.http://www.guru3d.com/articles-pages/asus-radeon-rx-460-strix-gaming-4gb-review,10.html Archangel (Desktop) CPU: i5 4590 GPU:Asus R9 280 3GB RAM:HyperX Beast 2x4GBPSU:SeaSonic S12G 750W Mobo:GA-H97m-HD3 Case:CM Silencio 650 Storage:1 TB WD RedCelestial (Laptop 1) CPU:i7 4720HQ GPU:GTX 860M 4GB RAM:2x4GB SK Hynix DDR3Storage: 250GB 850 EVO Model:Lenovo Y50-70Seraph (Laptop 2) CPU:i7 6700HQ GPU:GTX 970M 3GB RAM:2x8GB DDR4Storage: 256GB Samsung 951 + 1TB Toshiba HDD Model:Asus GL502VTWindows 10 is now MSX! - http://linustechtips.com/main/topic/440190-can-we-start-calling-windows-10/page-6 Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518604 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 11, 2016 I would recommend the AMD graphic card because of DX12/Vulkan/Mantle,over-enginnered to be more future proof than their counterparts and power effieciency. Link to comment https://linustechtips.com/topic/658709-help-choosing-gpu/#findComment-8518787 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
