Hello,
I am building my new pc this days and so far I have everything bit the gpu. The specs so far are: i7 6700k, msi M5 motherboard, evga 750W psu, 16GB or ram, 450GB SSD and a phanteks case. I choose a Dell u3415w as my monitor and now I try to choose my gpu.
My dyllima is the following one. To have one 1070 to start with or to go for an older solution and have two 970 in sli, bying one now and the second one after some time.
 I am planning to use my pc for design and gaming, mostly rally and fps, and I quoted like to have an average of at list 60fps.
Thanks for your time and I am sorry for the long post. I am waiting your answers
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/
1070: More VRAM, better performance, and better use in design and gaming.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8517287
1070 is way better choice then any SLI combo. SLI can be a pain. Also power consumtion is a concern, just like the "3,5GB" of VRAM on the 970 will be an issue with ultra wide resolution.
CPU: AMD Ryzen 9 5950X PBO GPU: Asus Strix RTX 3090 OC Mobo: Gigabyte X570 Aorus Master RAM: 32GB G.Skill Trident Z RGB 3600Mhz CL17
CPU Cooler: Corsair H150i Capillex Storage: Samsung 980 Pro and 970 Evo 1TB Samsung 860 EVO 1TB Crucial MX300 525GB WD Black 2TB PSU: Corsair HX1000 Case: Corsair 500D SE RGB 6x LL120
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8517300
1070 - 3.5GB of VRAM on the 970 is useless
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8517314
i have the same monitor and a GTX970 and i have to say that Vram aswell as power i often a problem. It works quite well but if you have the chance you better get a 1070 or 1080.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8517348
I see could you tell me your average fps?
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8517488
48 minutes ago, huilun02 said:
Average of at least 60fps at 3440x1440?
Sounds like GTX 1080
Spend about as much on the display as the graphics card is general rule of thumb
I know but a 1080 now is way out of my budget... A future update to a second 1070is more likely...
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8517500
Average FPS in what games? :D
I get about 120-140 in csgo maxed out :P
Just Cause 3 gives me about 40-45 also maxed out. If you want some other games benched just tell me but these are the ones i know exactly.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8517643
980Ti runs ultrawide 1440 pretty damn well. If you wanna run everything ultra with all the AA then yeah. A 1070 will be fine tho
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8517734
True every game is different... Games like dirt, Battlefield, need for speed for example. I know the more demanding games,  like crysis will have way less fps. As long as they are playable is OK for me.  For the beginning at list ?
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8518103
More vram the better. The Division(just the most recent game I've played) for instance never caps 7gb on my titan x in 3440 x 1440.
So obviously the 10 series is the way to go.
"The wheel?" "No thanks, I'll walk, its more natural" - thus was the beginning of the doom of the Human race.
Cheese monger.
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8518124
Looks like I have to go for a 1070 for better performance and to be a bit more future proof... By the way has anyone knows a company named galax??? They have here in UK a nice offer for a 1070...  Here is the link http://www.galax.com/en/graphics-card/10-series/galax-geforcer-gtx-1070-exoc.html
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8518311
I've used galax before, when they were called galaxy.  They make good stuff.  Anyway, the 1080 is better suited for 3440x1440 if your target is 60 fps.  That gpu will allow you to max out games (minus AA, usually keep that lower) and hit that target fps.   The 1070 might struggle.  Either way you want the 8GB of vram.  So, don't go below a 1070. I'd personally go with a 1080 over a 1070 (I'd get two 1080s, but that's just me).
Thrive on change. Embrace volatility.
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8520707
Sure 1080 is the best choice but to expensive... In sli even more. ?I think I will go for 1070 and maybe in the future  one more. Looks more logical for my current build
https://linustechtips.com/topic/658609-gpu-for-ultra-wide/#findComment-8521010
