I'll apologize in advance for what I'm sure is a very, very basic question...
I have a Benq XL2410T monitor that runs at 120hz, 1920x1080, 2ms but I'm considering upgrading to an Acer XF270HU (or something else).
My question: Can I run these together as a dual monitor setup (the benq using 120hz/1920x1080 but the Acer running 144hz/2560x1440) or do they have to be the same resolution and hertz?
Thanks
https://linustechtips.com/topic/658599-dual-monitors-basic-question/
If you would use them in surround which wouldn't be ideal with 2 monitors they would both run at the same res and hz. If you only game on one and the 2nd one is just at desktop then they both can run at their native resolution and refresh rate.
Thanks
nope they don't, it's nice if they are the same model, but it can be done with completely different monitors.
7 minutes ago, HungryHamster said:
-snip-
You can set them for separate resolutions. Don't expect to game on both though.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
