If you buy a 4x8GB kit. and you use 2 of the 4 (8GB) sticks in dual channel config. Will it work?
then you get to keep the other 2 8gb sticks to put it in another computer
thank you for answering my question,
Now I have a second question:
Is 1 4x8 GB kit is less expensive then 2 2x8GB kit?
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/65854-will-it-work-ram-channels/
yes it will work fine
 Motherboard - Asus Z97-WS ll Processor -Intel i7-4790K ll Cooling- Custom Loop ll RAM - Corsair Dominator Platinum 16GB(2x8) @2400 ll Graphics Card  - EVGA GeForce GTX 980 TI ll PSU - Corsair AX 1200 Watts ll SSD - Samsung 840 Pro 256GB ll HDD - seagate barracuda green 2TB & Seagate 4TB ll Case - Silverstone TJ11 ll Audio - Asus Xonar Essence STX  ll OS- Win 10 PRO 64-bit ll Keyboard- CM Storm QuickfireTK Green Switchesll Mouse- Logitech G502
https://linustechtips.com/topic/65854-will-it-work-ram-channels/#findComment-899630
depends but usually yes but only by a few dollars
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
https://linustechtips.com/topic/65854-will-it-work-ram-channels/#findComment-900762
